Bad battery life after replacement
I replaced my battery about a month ago with an OEM from here. All went well, and the battery works fine, except my time from fully charged is even worse than before... 3-4 hours tops, and often it goes from 25% to dead in about 1 minute.
I checked and my system profile says:
Full Charge Capacity: 3016
Cycle Count 35
Condition: Service Battery
Any suggestions? My computer is becoming rather unusable...
Thanks
Это хороший вопрос?
7 Комментариев
Does the old battery wear out at the same speed.
из John
no, it was not as bad as this. it was just a 3 year old battery... with like 600 cycles on it.
из rob999
Sounds like a bad battery?...the one you ordered ...try this run the thing all the way down till the laptop finally shuts off let it sit few hours don't turn it on let it fully charge then see what happens.
из John
That won't be hard, I'll give it a try.
из rob999
So I did as suggested. Got few hours out of the battery before it died.
Interesting, checked my System info and now get:
Full Charge Capacity: 2907
Cycle Count 35
So in one cycle the batter dropped about 100 mAh.... in capacity.
из rob999
Показать 2 больше комментариев
