ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
blows circuit breaker when press start
When I use the microwave feature, the circuit breaker pops. I thought that it was the outlet at first so I tried another outlet on a different breaker, same result. It seems to happen as soon as I want to "nuc" something by pressing start. I do not know how else to describe the issue so I hope that this is descriptive enough. Any advice or input would be greatly appreciated as this device is not that old. Thanks
ΠžΡ‚Π²Π΅Ρ‚ Π½Π° этот вопрос Π£ мСня Ρ‚Π° ΠΆΠ΅ ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ°
Π­Ρ‚ΠΎ Ρ…ΠΎΡ€ΠΎΡˆΠΈΠΉ вопрос?
Π‘Ρ‡Π΅Ρ‚ 3
1 ΠšΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ:
We have the same issue with Kenmore. It works fine until yesterday. The light and vent are working but when we hit start to heat food, our panel breaker goes off.
ΠΈΠ·
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
3 ΠžΡ‚Π²Π΅Ρ‚ΠΎΠ²
If you have used this in the past and it worked it is likely a bad breaker, bad microwave or you have added something to the circuit to over-load it. If you will let me know how much electrical experience you have I can maybe suggest some ways to narrow it down.
Jim
Π‘Ρ‹Π» Π»ΠΈ этот ΠΎΡ‚Π²Π΅Ρ‚ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
Π‘Ρ‡Π΅Ρ‚ 0
Since you tried the microwave on two different circuits with the same result I would suggest that the microwave has blown/burned out a component. Since some parts of the microwave circuitry could hold extremely high voltage even when unplugged, this is definitely not something you want to try to repair at home unless you are an electrical engineer or have experience in this area. Take it to a repair shop or buy a new one.
Π‘Ρ‡Π΅Ρ‚ 0
NOT a bad breaker. The problem is the door monitor switch. If it does not activate when the door is closed it places a dead short across the power lines and trips your circuit breaker.
It is either the switch or a worn trip mechanism. Disassemble and insure that the door is tripping the switch when closed. Some MWs are adjustable, some not. If not, replace the plastic tripper. If so, replace the switch.
Π‘Ρ‡Π΅Ρ‚ 0
Π”ΠΎΠ±Π°Π²ΡŒΡ‚Π΅ свой ΠΎΡ‚Π²Π΅Ρ‚
virgilv Π±ΡƒΠ΄Ρƒ Π²Π΅Ρ‡Π½ΠΎ Π±Π»Π°Π³ΠΎΠ΄Π°Ρ€Π΅Π½.
Бтатистика просмотров:
Π—Π° послСдниС 24 часов: 1
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 5
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 23
Π—Π° всё врСмя: 1,811
