Also known as the PS one, or the PSOne, this device is the slim version of the original PlayStation, released in 2000.
19вопросов Показать все
Darkened screen and distorted colors.
Hi! I have a ps one (the remodeled, smaller playstation) and Ive always used it gently. These days I rarely use it, but I always have it ready for use in my room. A month ago I turned it on and the screen looked darkened and the colors somewhat distorted. Videogamewise, the machine works and reads cds perfectly. Could it be a problem with the video output of the machine? Ive tried with different tvs and cables, and the result is always the same. A technician told me that this issue has no way of being fixed, and recommended me to change the motherboard. Is this true? Is there still a way to fix it without changing the motherboard? Thanks for reading! ;)
Это хороший вопрос?
Оценка 1
1 Комментарий
Thanks! Your suggestions make a lot of sense. Maybe i will take it to a general technician (not a biased, videogames technician) and he will be able to fix the unit. By the way, i just bought a ps in excellent state on ebay for 39 bucks. You were right! :D Thanks!
из
Добавить комментарий
1 ответ
Выбранное решение
Outside in a hot sunny day will not work. Using a heatgun would work but it is probably not the issue and a heat gun will more than likely burn or warp the board since it isn't a controlled heat it will not stop at the 300-600 degrees that would be needed. I think you may have a loose joint on the a/v connector itself. It is possible that the gpu has a issue but loosing color isn't the first thing that I would put on that kind of fault. (Lockups or no startup would be one that would point to it) Another thing to check would be a bad capacitor or resistor. It also could be a setting like progressive scan or ntsc/pal setting. Not sure since I do not have the unit in front of me. I find these systems at goodwill all the time for around 5 to 15 dollars.
Был ли этот ответ полезен?
Оценка 5
Добавьте свой ответ
bernardo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 36
За всё время: 8,967
