How do I turn on panel ligh?
My microwave (GE JVM3160RF2SS) works but I can't get the panel to light up and don't see a switch.
Any ideas?
Это хороший вопрос?
Any ideas?
Это хороший вопрос?
There is no way to light the control panel, bad design. Well I discovered a way to light manually and in a way that provides Incredible light with 2 settings. Even better, the microwave’s looks as if the light is part of the appliance. see photo. Easy to do, cheap and battery run. Photos below. I’ll be happy to describe how I did if you want to know.
Был ли этот ответ полезен?
YES!...please explain how you lit up the panel...Thank you!!
You can purchase. These from Amazon. Get heavy duty small magnets “”monkey” magnets great. Amazon. Turn light on side, add 3 magnets to bar, match up on microwave. See photo above. Looks great, works great.
Under Cabinet Lights with Remote, Magnetic Rechargeable Under Counter Closet Lights, Wireless Night Light Bar Stick-On, for Kitchen Wardrobe Cupboard Stairs...
My problem is you can't see the clock in the daylight to know how many minutes are left for cooking, or for that matter did you put in the correct minutes and power
What kind of light did you get? Can you please give an order number or something.
Thanks!
I added a small number button to the ON on the panel to turn on light in the dark…
Can you please explain how to do this? The panel on my microwave has no “On” button except for “Timer On Off”
How & where did you add a button to light things up?
Was the number button solar so it lights up in the dark.
The model I purchased does not have an ON button. Has a Cook Time button.
What he means is to put some distinguishing mark on the button that controls the surface light (under microwave light) to make that easy to turn on and then the light from that aids in seeing the control panel. It is a good workaround to a very stupid design flaw on GE’s part.
To turn on a panel light, check the main power source for home or office lights, or look for controls on the device itself, such as a switch on the wall or a dimmer knob on a car's steering column. For a computer's panel lights, you may need to use specific motherboard or software controls.
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 59
За всё время: 24,260
29 Комментариев
not talking about surface light talking about the control panel light so i can see the buttons to push have to turn kitchen lights on high to use this product
из tina
I have the same problem and I have talked to numerous GE people and they have no solution to the problem. Their only response is basically that is the way it is. I'm not happy with their response. They should provide a solution.
из Darlene Moynagh
Obviously, flawed design by the same person that fashioned the Titanic
из mdsbarry
Totally agree. Microwave looks nice and is running well BUT is extremely hard to operate when you can't see the display.
из Linda Abboud
Panel display impossible to see . My last GE product.
Their stock price reflects the company downward spiral.
из randresid
Показать ещё 24 комментариев
