Released September 2013, the Visual Land Prestige Pro 7D model number ME-7D-8GB is an affordable and sturdy tablet designed for kids.
Вопросов 20 Показать все
charger port missing prongs- needs replaced
Prongs are missing in the charger spot. Is there a way to fix it?
Это хороший вопрос?
Оценка -1
Добавить комментарий
Ответов (1)
Thanks for your question.
Sorry for your troubles.
Yes you can fix the port however it will require ordering the correct repacement port AND knowledge on how to solder the new component onto the circuit board.
If you are going to do this yourself than might I suggeste that you order at least two replacement parts. Just incase one of them is defective.
Hope this helps.
Good luck.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Veronica Whitton будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 105
