Планшет Maylong Mobility M-270 — это легкое устройство с 7-дюймовым экраном.
Tablet stuck on boot screen with a red triangle in belly.
I have a m270 and it is stuck in a boot screen with the android man laying on his back with a stomach flap open in the middle of that is a red triangle with an exclamation point in the middle. Please help.
Это хороший вопрос?
Счет 0
Добавить комментарий
3 Ответов
pictures? so i can see what you mean
Был ли этот ответ полезен?
Счет 0
My tablet is stuck showing the little Android
Счет 0
Despite this being over a year old, I'll still answer it. The device needs to be wiped and the firmware needs to be re-flashed onto the device. I was able to repair a few units with this. The only problem is now, since the Maylong has folded and is not longer in business, the firmware download link is no longer active.
If you were able to do a search and find it, there are two files that can get loaded directly onto a blank micro sd card, and put into the unit before powering on. The device will load the files, wipe the old firmware, and install the new one.
Счет 0
1 Комментарий:
I have a apk file, just need instructions on preparing the sd card for install.
из Поделиться
Добавьте свой ответ
Markiese Walker буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 39
За все время: 696
