Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
spacebar doesn't work not
spacebar stopped working. no spills, not a hardware issue. when spacebar is pressed spotlight comes up this happens without the command spacebar being pressed.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Check your command key. It is possible that something is pushing down on the button in between the key. If not then check your Bluetooth settings and replace the batteries of the keyboard to see if that may be a problem. If possible try using another keyboard and see if it gives you a problem with the space-bar, if so then it could be a software setting, maybe in accessibility settings. Hope this helps!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
faedra james буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 35
За всё время: 6,595
