iPad2 16 GB Screen blank. Cannot boot.
iPad2 16 GB not booting.
Это хороший вопрос?
Try a new charger & cord, look for visible damage to the charge port or corrosion. Do a hard reset, hold power and home button at the same time. The Apple logo should pop up after about 10-20 sec.
If all that doesn't work you would need to disassemble the iPAD and disconnect the battery for about one minute and then reconnect. You can have a local repair shop do this for you if your not comfortable.
If that doesn't work there is a board level issue and it might not be economical to repair.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 84
jttowner, what have you tried? did anything happen to the iPad? Have you charged it on a proper charger?
из oldturkey03
