PS4 controller battery problem
I have a problem with my ps4 controller. It doesn't work without it being plugged to the charger, plus when it's plugged in I feel heat in the controller. When I unplug it after probably a minute it turns off.
So can anyone help me out?????
Это хороший вопрос?
Счет
4
I have this same problem, it happened to both of my controllers on the same day. I have changed the batteries and the problem still remained. I also tried changing the charging port circuit card and ribbon cable, but then I couldn't the controller to work even with it plugged in. Also, the LED only lights up intermittently. I hope there is some sort of answer for this issue out there.
из fredj2001
I changed battery and the usb port on the controller and still the problem didn't disappear
из Amer
