Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
wifi greyed out and bluetooth keeps spinning
My iphone 6 wifi greyed out and bluetooth keeps spinning, wasting valuable data, everything else works, I recently replace my digitizer and glass and now this. I reset everthing, rebooted phone to original from itunes, maybe I left something loose, any suggestions or help.
Это хороший вопрос?
Оценка 2
Добавить комментарий
3 Ответов
That means the wifi/Bluetooth flex has been damaged and needs replaced. I would replace it after factory resetting your phone first.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
If Wi-Fi is greyed out (can't turn on) it is more likely a board issue (could be software but unlikely). Usually the Wi-Fi ic chip going bad.
из
I have the exact same problem, just got the flex ribbon, and am attempting to replace now. Wish me luck. Question, how can you tell if the antenna also needs to be replaced? I would rather not crack this open twice.
Оценка 0
Did anyone have Luck With this I have an iPhone 6 With the same Problem
Оценка 0
Добавьте свой ответ
wayne будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,413
