Вопрос закрыт
Can not view pictures, storadge space is running out
I get a message that storage space is running out . Therefore I tried to delete some pictures , but I get a message that there is not enough space (20MB) in your device memory. Delete some files. How do I solve this?
Это хороший вопрос?
Оценка 0
Добавить комментарий
4 Ответов
Hello,
just simply connect your phone to PC and copy content on PC.
Был ли этот ответ полезен?
Оценка 0
I have done it, but it will not allow me to delete the pictures as I Can not open the gallery.
Оценка 0
1 Комментарий:
Can u put SD card in tablet and then copy some contect on SD card?
из
No I can, t. I get that messege and when I answer it ok or cancelled, it takes me back to the icons. Will not allow me to open gallery, therefore I can, t delete any of the pictures to free memory.
Оценка 0
I would suggest if you (only copied the files) to reconnect the Tab to the PC and "navigate" to the media folders and delete the files manually. Also as long as you are sure you copied said files.... I'd like to venture a guess a "factory restore" may be of some help. Don't worry, if you have paid apps on there you can still get them back.
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 6
За всё время: 54
