Kenmore Elite HE3 — это стиральная машина от компании Kenmore. Она идентична модели Whirlpool Duet.
meaning of OE code
getting OE code and does not drain/spin
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
@ronhurley the error code "OE" is a "Drain error " and it is initiated by your washer not having fully drained in 10 minutes. Most common cause is a clogged filter. Check your "coin trap" filter for retained objects, like missing socks etc.:-)
To clean it
1. Take off the lower front panel
2. Turn the pump filter cover counter-clockwise by hand and remove. Place a bucket or pan underneath it since you will get water spilling out of there.
3. With a set of long pliers, remove the filter. Clean that of any debris etc. and replace it when cleaned.
4. Replace the filter cover and lower panel.
The other thing that could be going on here, is that the drain pump is not working and needing to be replaced. The service manual will have instructions on how to do that. There is also a decent video on here.
There will be plenty of water. So please make sure that you have lots of buckets and towels etc. to catch the water. It will be a stinky, dirty flood
You can download the service manual from from here.
Был ли этот ответ полезен?
Счет 6
10 Комментариев:
Have cleaned outf ilter blow hose clean still same fault
из
I followed this and didn’t fix anything. I am guessing the pump is clogged or not running at all...good luck
из
Worked for me , I just hope it stays working! Thanks
из
I had to replace the drain pump, 20 something bucks on Amazon. Not to hard but can be challenging for some. Fixed the problem.
из
Thank you so much. This did the trick!
из
Показать ещё 5 комментариев
Добавьте свой ответ
rhurley52 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 57
За последние 30 дней: 268
За всё время: 122,526
