Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797вопросов Показать все
Вопрос закрыт
I just receive the battery I bought. doesn't work
I bought a direct replacement for this iPod.
Installed it per directions.
It says it's fully charged, but when I unplug the charger, it all fades away.
I've done a reboot twice now.
Это хороший вопрос?
Оценка 0
2 Комментариев:
@rosadoco does it only say charging when plugged it? Does it do anything without the charging cord plugged in? You double checked to make sure that you have the battery cable properly inserted? What happens when you reinstall the old battery?
из
It does say charged (the plug, not the lightning bolt) ONLY when plugged in.
When I unplug the charging cord, it fades to nothing.
I have rechecked the battery cable several times. It is firmly attached to the plug.
It begins charging with the old battery, when I reinstall it.
из
Добавить комментарий
1 ответ
By experience, it's either a bad contact on the installation, but because you can actually charge it I would tell you you've received a defective unit.
Keep in mind you might as well have an other issue linked to the iPod. But I doubt it !
Good luck !
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I don't know if I can actually charge it. It simply displays the "plug" symbol that indicates it is charged. When I unplug it, it fades to nothing.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 55
