Hi @JB6000
If it still won't connect to a PC try the following.
Try starting the phone in safe mode to see if it will connect OK to a PC.
Not quite sure with a Blu phone but with most Android phones to get into safe mode, turn the phone off by pressing the Power button. When the shutdown menu options appear press and hold the Power Off option. There should be an option to start the phone in 'safe mode' Tap that and allow the phone to restart. Once in safe mode see if you can now connect to a PC.
If you can then a downloaded app is the cause of the problem.
The trick is to find out which one. You need to uninstall each downloaded app one by one and test the phone between each uninstall to see if it now works OK. If it does the last app that you uninstalled is the culprit.
To get out of safe mode, simply turn off the phone in the normal manner and restart it.
If it still won't connect to a PC in safe mode, try a hard reset.
Be aware that a hard reset will erase all your data and downloaded apps. It will restore the phone to its factory default condition, (or last system updated condition).
Perform a backup of the phone, using the phone's backup feature first, before you do a hard reset.
Then perform a hard reset using the phone's factory restore feature.
Once the phone has been reset, try connecting to a PC via USB.
If it works, restore the phone with the backup that you made earlier, using the phone's restore feature.
Once it has been restored, check if you can connect to a PC via USB.
If you can then the reset has resolved the problem.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
14 Комментариев
I’m having the same problems. Tried all options above still not working, it’s still charging though..
из kazuriya13
I have this same problem. My phone shows up in the devices panel of my PC running windows 10 but I can’t seem to access it. How do I actually access the phone so I can download pictures from my phone to my pc?
из Anna Westgate
On Win7 Start/Default Programs/Change Autoplay Settings.
You can do something here, most likely.
из John Butkans
hi
i am using a small device by the name of stylo its not a smart phone but it has an access to internet but i cant connect at all, how can i fix it?
из Sphiwe Meshack
Problem is, my phone's 'Advance' option just disappeared from my 'settings' menu.....why is that happening too?
из Gideon
Показать 9 больше комментариев
