Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98вопросов Показать все
Plugged into Asian outlet abroad
Stupidly plugged it into the outlet in Beijing, it made a buzz sound and has never worked since. That was a year ago. Back in the US and would love to fix and use it, especially since it was brand new when I messed it up. Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Plugging into China's 220V outlets probably burned out the power supply or transformer in the Keurig. I'm not sure if you can get replacement parts for that, but you could check on Keurig site.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Julie kim будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 247
