Time Capsule is overheating w/yellow flashing light
Has anyone successfully repaired a Time Capsule that's overheating all the time? The yellow light is always flashing and when I pull up AirPort Utility it says "this device may be overheating." The device does feel warm to the touch (not hot). I've called Apple and they say they can't fix it and won't replace it since it's not under warranty any longer. I'm considering cracking it open to see if cleaning out dust and whatnot might improve air circulation and fix the problem, but I'm curious if anyone else has done this before?
Это хороший вопрос?
24 Комментариев
I'm keen to understand if you got this resolved. Mine is doing the same thing however my TC hard drive seems to have failed as I can't back up to it or read from it. The only error I have is that it may be overheating. Like yours, it feels warm but no warmer that I'd expect. I can't seem to clear the error at all. I decided to test it by putting it in a cool place for an afternoon thus ensuring that it was not warm before plugging it back in. Same error. Does this mean the drive has failed/jammed and is resulting in heat build up? I'd have thought there would have been a discreet error message for that.
Cheers
из Niall Carney
I ended up pulling the HD out and selling the Time Capsule itself for cheap. The HD still worked fine and I've been using it with an external USB dock for Time Machine backups. Cleaning the Time Capsule didn't work. I even left the case off and it ran fine for a few hours but started complaining about overheating again. Apparently it's a common problem. Sorry I couldn't find a better solution, and sorry that your HD appears to be fried.
из Matthew Bass
Could someone post where I could find disassembly instructions/guide? Pretty sure the fan on my Time Capsule is stuck. Thanks.
из Rico
The solution (for me) was to disassemble and lubricate the central spindle of the fan - as mentioned above. Works like a charm. But... it is NOT easy getting to the fan and the tiny clips that hold the fan housing together break VERY easily. With even one of them broken the fan housing leaks air down the seam making it less efficient and will cause the same over-heating problem all over again. IF you do break one, like I did, just use a tiny drop of super-glue, as small as you can get on the tip of a sewing needle and dab it where the broken clip is (was). You don't want to seal it for all time. If your micro-drop of super glue is small enough you should be able to crack it open again with an exacto-knive if you ever need to lube the fan again. But I'm not sure why you'd still be using this lousy paper-weight at that point. But it really does work. Blinking orange light is finally off (or broken).
из Jesse Morano
AirPort Extreme A1521 Teardown here's how to get to the fan. Go slow.
из Jesse Morano
Показать ещё 19 комментариев
