Battery Status shows "Not Charging", Power Supply is OK
My PowerBook G4 Aluminum 1.67 Ghz stopped charging the battery as stated in title. Checked OEM power supply and it has full voltage and amp supply. Apple Help says that when "Not Charging" appears, power supply is too weak e.g. aircraft power supply being used.
Computer starts up and operates fine just on power supply.
What other problems can cause this? Battery was holding charge before this happened.
Thanks in advance for your help!
John
Это хороший вопрос?
1 Комментарий
Download and run (free) Coconut Battery 2.6.6 and give us your results: http://www.coconut-flavour.com/coconutba...
из mayer
