Where are the power pads to short it on?
I’m looking for the pads to touch to short it on to check to see if my keyboard is broken.
Это хороший вопрос?
Это хороший вопрос?
David Molinari you can do this by either shortening pin 5 of the keyboard connector briefly to ground. You can also use the debug pads as pointed out.
Был ли этот ответ полезен?
Thank you very Much oldturkey03!
Hey! When I short the two pads it turns on but the fan goes on at full speed and doesn't stop. Where is keyboard connector 5 by the way? Thanks in advanced!
Hi, thank you so much!!!! I've been searching these power-on pads for so long...
I "only" have to replace the keyboard now.
Must i disconnect the keyboard in order to power up with power pads ?
francoisvdc no you do not.
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 77
За всё время: 22,735
