Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
Stuck in a reboot loop after repair
I put a new frame on my iPhone 5s and put it all back together. I had it working except the screen didn't want to rotate so I took the front screen of again to try to solve these problems. I reconnected the LCD cables and home button and now I am stuck in a reboot loop, and my screen has a horrible line down the middle. I have had this problem before and I figured out it was just the screws being in the wrong holes on the LCD cable shield. I had the screws in the right holes but yet I am still in a boot loop. I currently have the shield remove from my iphone and it's still in a boot loop and it won't restore on iTunes. I have also tried Reiboot and it didn't work. On iTunes I keep getting Error 9 or the device can not be found. Please help!
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (1)
Наиболее полезный ответ
I would remove all the screws from the board to see if something is causing a short or flexing it. Can you test the device with a different screen?
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I do not have a different screen to try but I will try to remove some screws
из
Добавьте свой ответ
beeweezy18 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 145
