The Nokia Lumia 930 is manufactured by Windows mobile and first released July 4, 2014.
Phone restarting or freezes whenever it wants. Any suggestions?
I do not remember exactly, if it has started doing that after I have dropped it to the tough surface or before. However, phone restarting or freezes whenever it wants. Mostly when phone getting charged, it is next to me (no matter if it charges wireless or wired) and I observed it restarting or freezing more frequently when it is charging.
Freezing in this instance means that screen goes black, as if it would be turned off and phone does not respond to any button or screen commands. You cannot turn it on by pressing power button and only restart with power and volume button turns it on.
Might be helpful. Phone has some visual defects after aforesaid drop:
1. Dent on the top backside (speaker side) - http://rghost.net/7qS7qD46w & http://rghost.net/7bYtzyK9m
2. Surface of the screen at the top where the "Nokia" writing is, is little higher than aluminum side facing - http://rghost.net/6lK9GhdQw
I had proximity sensor problem as well as all above and official service could not help me (I think they are just useless in my country) reporting that they have replaced the proximity sensor (which is still a problem).
Any suggestions how to fix it?
Это хороший вопрос?
Оценка 2
Добавить комментарий
Ответов (2)
Do it yourself if you feel comfortable, look into youtube videos internet etc research the crap out of it, It could also just be your processor or something got knocked loose when you dropped the phone.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I am sorry, but your response is not helpful at all, this type of answer can be adopted to any situation.
из
Well, try restoring with Windows Device Restore Utility. If that doesn't help, check out this guide, open your device and try to figure out what's wrong: http://www.smartphonefrance.info/Techniq...
Оценка 0
Добавьте свой ответ
ndadashev будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 836
