Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143вопросов Показать все
How can I exactly locating the physical bad sector
how can i exactly locating the *physical* **bad sector** ?
_&_ what's best way to locate it ?
_&_ and kindly provide me the best program for detecting if the **hard-disk**
has *bad sectors* or not ?
i have tried with this program "Hard Disk Sentinel" but i think it's not work
waiting for your kindly answers
Regards
Jebrel
Это хороший вопрос?
Оценка 0
1 Комментарий:
What model hard drive? What model computer? what errors do you get? Does your computer recognize your drive? What have you tried?
из
Добавить комментарий
1 ответ
  1. Go to the search bar and type “Command Prompt”. Click on “Run as Administrator”.
  2. Type the command “chkdsk C: /f /r /x” and press Enter. (Or the Drive letter which is having the bad sectors)
  3. The utility will scan the hard drive for errors and attempt to fix them.
  4. Restart your computer and see if the error is resolved.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
jebrelayoub будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 102
