This LG Tribute smartphone is identified by model number LS660. The device was released in October of 2014 and runs on the Android operating system.
30вопросов Показать все
Why won't my phone charge?
When I plug my phone in it doesn't recognize that it is charging or connected.
Это хороший вопрос?
Оценка 5
Добавить комментарий
3 Ответов
Gus-
If your phone is plugged in to charge but does not recognize a connection then the first thing I would do is test the chord. Either use your chord to try charging another device or use a different chord to charge your device. If your chord is working then my second suggestion would be to clean out the charging port with compressed air. If your chord is good and your port is clean then I would say you might need to replace your charging port. Take a look at the LG Tribute Troubleshooting page.
Был ли этот ответ полезен?
Оценка 0
Try removing the battery, then plugging in the cord. After at least 30 seconds, add the battery with the cord stil l in. It should take a while, but it will charge.
Оценка 0
I had that problem i changed my charger and blow into the pert where charger goes mine was going crazy its fine now
Оценка 0
Добавьте свой ответ
Gustav Wolter будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 6,762
