Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
My phone got very hot, then the screen stopped working?
So a couple days ago, I traveled from chilly New York weather into very hot weather in Costa Rica. Shortly after I arrived in Costa Rica, my phone started getting very hot after me just using snapchat for a mere 5 minutes. It got so hot it hurt to hold and then the screen went black. I knew the inside lf the phone was still working because I'd plug it in and it would make the sound or I'd flick the ringer and it would buzz. So I held down the power button to turn it off and the phone cooled down. I tried restarting it by holding the home and lock button (although, not for a long time.) Nothing happened. Now its been nearly 3 days and I've had no luck. How can I save my phone?! There is no Apple here!
Это хороший вопрос?
Оценка 4
2 Комментариев
Ok, thanks anyways :(
из
2 days ago i was taking a bath and i dropped my iphone 6 in the bath for about 3 seconds and it was ok other than the speaker so i put it in rice over night and the speaker was working it was working fine, than i was watching netflix on it and it just shut down and i can't replace it or anything it is charged but it keeps getting hot how can i get it to turn back on?
из
Добавить комментарий
6 Ответов
Выбранное решение
Hi,
By the sounds of things, your phone is still receiving power "I'd plug it in and it would make the sound or I'd flick the ringer and it would buzz"
This sounds to me like your screen has gone bad, I would highly suggest trying a new screen.
You haven't mentioned it being dropped in any sort of liquid, so I'm ruling out liquid damage unless of course you have dropped it in liquid.
Open the phone up, disconnect the battery, disconnect the screen, and try a new screen, hopefully you will get somewhere.
There are plenty of guides around to disassembling the iPhone 6, so that shouldn't be an issue, just take your time.
Any questions, feel free to ask! :-)
Был ли этот ответ полезен?
Оценка 3
6 Комментариев:
mine randomly started over heating for no reason. My pants were a little wet. Did it short out? It got extremely hot and the screen went black. Its been only a day since this happened.
из
As compared to my phone,I dont think that there is issue with point which u mentioned above, during the heavy summer am handling the same issue with my phone.It is completely dark on my display.If i press the home button, then it will take excacly 25 Seconds to re open the display,..i dont know what happened..can u please assist me to save my phone..??
из
well I have a similar problem however the screen of my phone fell on the floor face down then the screen went black then the selfie camera got really hot. and its not working at all I tried reseting it so I can feel my phone vibrating and nothing happened! what do I do in this case I'm in a frown island they don't have an apple store of any kind! please tell me there is a solution!
из
Mine did the same but starting working when the battery went completely down. I knew it was still on because I could see it on my car’s Bluetooth. No sure why but it began working when I plug it in with charger and could see the low battery with thin red line icon. Working great since then!
из
So , I put my phone on charging and it charges in about 3 or 4 hours maximum .it was working very fine and good. I forgot to unplug it in the morning .I checked my phone and it was continuously restarting itself. It was extremely hot so I took out the battery and cooled down the system . After cooling , I put the battery back and started my phone but it was like my phone hanged or something and it started re heating . After entering the password it stops working and does not shows any apps or anything except wallpaper and then after about 30sec it shuts down itself. It happens again and again . What should I do? . I've very important data in mobile I cannot risk wasting anything and also there are no phones available of the same model here. Kindly reply please.
из
Показать 1 больше комментариев
Check your battery tab in settings and see if anything is draining an exceptional amount of power. if nothing seems out of the ordinary backup and DFU your phone. Before restoring see if an unloaded stock OS still produces these issues. that being said, it sounds like your phone may have suffered water damage and I would get it looked at ASAP.
Оценка 0
1 Комментарий:
Ok, thanks for the help!
из
As mentioned, water damage could be the cause. Remove the motherboard and brush the components and connectors with a toothbrush and pure alcohol. If possible you can bring it to a workshop who could decontaminate it more thoroughly.
Оценка 0
2 Комментариев:
из
i can’t figure out how to take the phone apart
из
Mybe u can go to seting, general, reset, and reset and all content. Try for software first before touch hardware
Оценка 0
Thea I know its a little late but it sounds like to me you blew out the backlight filter due to a short inside the phone. Typically when the phone gets excessively hot it is due to a short. Has the phone ever been in water as that is the usual reason for a short. Either that or a botched screen replacement. The good thing is your phone is not toast, this can be fixed. You need to find a repair shop that specializes in micro soldering on mobile devices. If there are none in your area there are quote a few that accept mail ins. Check out Jessa at iPad Rehab. Here is the link www.mendonipadrehab.com. If you just want your data and you can see the home screen with a flashlight as previously commented you can use the flashlight to navigate your phone, back it up and buy a new phone. At this point it is about cost versus replacement. Good luck!
Оценка 0
My iPhone 6 gets hot and cannot turn on. The whole night it was on its charge, because the battery was red.
In the morning when I waked up, I removed the iPhone from its charge, and trying to open it, but I can’t because the iPhone was very hot and the display was black. I tried to removed the SIM card from my iPhone, and after that replaced again inside my iPhone, and tried again to turn on the display but I can’t.
Now my iPhone is with black display, its not too hot how its was an hour ago. Now its cold but without the power or working display. I never before has this with my IPhone, which was happening last night or today, I really don’t understand what is happened with my IPhone? How can I used it, when its doesn’t work normally? I have a lot of things already inside my phone, how can I preserved my memories when the IPhone doesn’t work correctly? What can I do, please help me with your advice! Thanks for you helping
Greetings from me, Dori
Оценка 0
2 Комментариев:
may I know how's your phone now?
из
Have u managed to recover the photos and data?
из
Добавьте свой ответ
Thea Tros будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 10
За последние 7 дней: 72
За последние 30 дней: 315
За всё время: 106,583
