Unibody MacBook Pro models with 13" displays produced from 2009-2012.
4630вопросов Показать все
New battery not performing as expected
Recently replaced the battery of my 2009 13" MacBook Pro ( new battery sold by IFIXIT), as well as a fresh install of the El Capitan, however I am not getting the 10 hours of battery life as advertised. I would approximate as closer to 4-5 hours. I am wondering if my battery isn't lasting as long as it should due to heating/cooling issues....any suggestions?
Это хороший вопрос?
Оценка 3
Добавить комментарий
1 ответ
Наиболее полезный ответ
First thing here is to reset SMC. Follow this Apple T/N: Resetting the System Management Controller (SMC) on your Mac.
Next thing here is let the computer charge a good 16hrs. Then disconnect the charger and run the battery down. Once its worn down recharge again for a good 18hrs. What you are doing here is making sure SMC is calibrated to your new battery. Here's a good write up: Calibrate & Maintain Your MacBook Battery For Best Performance. I recommend you download this little gem of an App: coconutBattery it will give you a better view on what is happening with your systems battery & charging.
Additional Reference: Maximizing-performance
Был ли этот ответ полезен?
Оценка 3
5 Комментариев:
coconutBattery is showing that my battery is only charging to about 75% of it's design capacity. I understand the "maximum charge" and "design capacity" are not going to line up exactly, but it seems like I'm off by almost 1500 mAh
из
Did you reset the SMC and calibrate the battery? If not give that a try first if that doesn't fix it you got a bad battery you'll need to return it/replace it.
из
Could you tell us your exact machine and give a link to the battery you bought? Also why you replaced the old battery and what was happing with it.
из
I reset the SMC and calibrated the battery as instructed. The battery life improved marginally, but then I noticed the large discrepancy between the design capacity and the maximum charge on coconutBattery.
I have a 2009 Macbook Pro and I purchased the battery from iFixit ([связанный продукт отсутствует или отключен: IF163-019]). The old battery was still working, but the battery life had diminished over the years. I replaced the battery with the hopes of increased battery life, similar to when I bought the laptop 7 years ago.
I also upgraded the hard drive to a Samsung 850 EVO 500GB 2.5-Inch SATA III Internal SSD at the same time, I am not sure if this is relevant.
из
Do you need anymore information?
из
Добавьте свой ответ
John будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 620
