How can I remove stripped Torx T2 screw?
I am using Japanese 3G vita (PCH-1100) and I was going to replace the 3G networking card that shipped from Europe. (to elimate SIM Lock.)
but unlike other reigon vita's, mine have a two of Torx T2 screw is tighten in 3G card.
so i bought dirt-cheap T2 screwdriver from local store and this thing stripped the screw :(
how can i take out this stripped T2 screw?
I tried rubber band method / soldering screwdriver to screw / put loctite 401 to screw head and stick screwdriver in to stripped head but none of this trick worked.
can anyone give me a advice ?
p.s: I got a spare screw so I don't bother if screw is destroy during removal.
Это хороший вопрос?
1 Комментарий
Drill it then use vise grips, an easy out could work . Depends on how bad it is. Make sure the drill bit you use is of good quality
из Brian Manuel
