The Canon PowerShot SX160 IS is a 16.0 megapixel digital camera with a 16x wide-angle optical image zoom and a 3.0 inch LCD.
Why does my camera not hold the date and time?
EVERY time I turn on my camera a screen comes up asking me to set a date and time. I do so, it says the date and time is as I set it. However, when I turn it back on the same screen comes up. When pictures are downloaded in my computer. the time is set to 1980!!
Это хороший вопрос?
Счет 33
11 Комментариев
can you help me set them time on my canon powerShot SX160IS?
из
Glad to have found the answer - I didn’t even know there was a battery there!
из
Thank you!! This was starting to annoy me.. Fixed on my powershot s5is, battery was tucked away beside my other battery's.. Didn't even know it was there
из
The date /time battery compartment is right beside the 3rd AA battery in the camera. It says CR1220 - that is the size of the tiny battery that goes in there. Hope this helps.
из
Thanks! I figured it out finally.
из
Показать ещё 6 комментариев
Добавить комментарий
6 Ответов
Выбранное решение
@darla this is common once the RTC (real time clock) battery is depleted. your camera will not remember the time and date without this battery. Changing it by using this guide should resolve this issue.
Был ли этот ответ полезен?
Счет 40
15 Комментариев:
Great. They should have put a memo in the box with the camera. Thanks.
из
It's been so long since I've used my A540 that I'd completely forgotten about the RTC battery, but that's what the problem was, all right. Thanks for the reminder!
из
I've done this and it's still not working. Any other suggestions?
из
When you say "not working," do you mean it still asks for the time and date even after you've replaced the battery? I can only suggest that you make sure the battery is fresh and that you insert it right side up. If the camera works otherwise, I can't think of what else it might be.
из
Yes, I meant the date and time still do not work. I've checked the battery with a voltage meter and it definitely works. I've reinserted the battery multiple times, looking at the pictures above and other sources.
I'm stuck.
из
Показать ещё 10 комментариев
Had the same problem with my Canon Powershot SX20 IS. Found this little battery compartment that holds the CR1220 on the bottom of the camera inside where the main batteries are installed. Just open the bottom battery compartment and you will see the small little part you need to slide off. You may need a small flathead screwdriver. Hope this helps someone else out there.
Счет 11
7 Комментариев:
Different Camera - Powershot A1200 - but this is exactly the relevant Information. Thx!
из
THank you very much! I had this same problem and just thought I camera was done for! problem solved!
из
Well thnx lol sitting here getting frustrated
из
Thanks for this. Is that even in the manual? No idea/
из
из
Показать ещё 2 комментариев
Try changing the tiny battery on the left side, on the top, pry open w/ your fingernail and replace this. I found this info doing a search online mine said CR-1220, its like a button battery, hope this works for you!
Счет 5
4 Комментариев:
I replaced the battery. It still does the same thing.
из
OK. The battery must be inserted into the guide flat down. Now it works.
из
This works for the A520 and probably other A510 series. That battery has lasted for 15 years!
из
Thanks yes it was the RTC
из
I happen to have this exact same model camera and the same problem! To think, I only searched for Canon camera date reset in Google and it brought me right here!
It does appear the problem is the CR1220 button battery needs to be replaced. I think these can be found at most drug stores.
Счет 1
1 Комментарий:
I found a replacement battery ok but it still won't save the date and time!
из
Счет 1
2 Комментариев:
The image is our old ps sx20
из
Thanks for your suggestions I am about to buy a new one. It’s help me to change the lithium battery.
Thanks again
из
I bought the battery t london drugs with tax like 10 bucks they said camera was older but they still caried that brand battery no problm in getting them,
and when i chnged it my time and date stayed set after i shut it off then on again,
problem solved
Счет 0
2 Комментариев:
Will it work for model Power Shot A460?
из
Can one change the built-in date/time battery in a Canon IXUS 185?
из
Добавьте свой ответ
Darla Hare буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 11
За последние 7 дней: 110
За последние 30 дней: 495
За всё время: 86,575
