Ноутбук Samsung Chromebook XE303C12-A01US оснащен 11,6-дюймовым экраном и твердотельным накопителем (SSD) объемом 16 ГБ. Этот компактный ноутбук обеспечивает легкий доступ к Интернету и позволяет запускать различные веб-приложения.
Can RAM be upgraded?
Can RAM be upgraded in this Chromebook? The module listed in the specs is 2GB DDR3L RAM. This is readily available in 4GB and 8GB kits. The Chromebook gets sluggish over time and this would be a great help
Это хороший вопрос?
Счет 4
6 Комментариев
Your answer is INCORRECT. It seems that the RAM is soldered to the board (this is an SOC board, System On a Chip) and has no user serviceable memory slots.
из Поделиться
How do you upgrade the chromebook
из Поделиться
I think the problem is more or less that the chromebook gets sluggish over time and not that there very little ram.
Try a ram cleaner maybe?
With the newest Chrome OS, you might be able to install a ram cleaner app from the google play store.
( I have a black Samsung chromebook 3 )
из Поделиться
which ram cleaner???
из Поделиться
Ram cleaners don't help. You need to stop programs from running automatically. If you run a program to clean ram, that program is likely using ram, and it's just shutting down programs that are auto-running anyway. And process repeats once you reboot PC. In command prompt type in "services.msc" to bring you to page to manually change program startup behavior. Alternatively, press Ctrl+Alt+Del, go to Task Manager, click on startup tab to shut down from there. Microsoft OneDrive is one that auto runs.
из Поделиться
Показать ещё 1 комментарий
Добавить комментарий
4 Ответов
Выбранное решение
There are no RAM card slots; the RAM chip is soldered to the board. But there is another way to upgrade your RAM. You can enable swap memory, which uses part of the SSD as RAM : 1) Open a terminal by typing CTRL-ALT-T 2) Type this as it appears: swap enable 2000 3) Hit ENTER, then restart your Chromebook. You can make the RAM swap size whatever you like/ need, I believe it’s up to 6GB (swap enable 6000).
https://www.maketecheasier.com/create-sw...
Был ли этот ответ полезен?
Счет 6
2 Комментариев:
Thanks for the tip!
из Поделиться
how do you undo (turn the RAM back into memory.)
из Поделиться
Unfortunately No,
Like this type and many other Chromebooks the RAM is solderd directly on to the motherboard.
I'm Sorry
Счет 5
You could, I guess, with a little patience and a lot of luck, unsolder the RAM and put on a different one. It’s way easier to rewire Chromebooks than other computers…
Счет 1
3 Комментариев:
Does it need to be a solderable ram to be able to replace the original ram? Or can i replace the original ram with attachable ram
из Поделиться
@tejaspatil5468 yes, it will have to be the same type of RAM. You can't substitute with removable RAM modules.
из Поделиться
do you know which ram is used in Samsung Chromebook 3 ?
из Поделиться
I like to eat Ram!
Счет 0
Добавьте свой ответ
Matthew Carpenter буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 56
За все время: 20,797
