Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance. Released in 2012
shutter error message on display
shutter error message, can't see through the lens
Это хороший вопрос?
Счет 0
1 Комментарий:
What's the exact error message you're getting?
из
Добавить комментарий
1 ответ
could you elaborate on the problem, you say you cant see through the lens, do you mean through the viewfinder or can not use live view. if you cant see through the viewfinder it is likely that the mirror is locked in the up position and could need to be freed, this would be consistent with the error message you are getting.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
eric буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 246
