Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
The backlight works but no display...?
I dropped my iphone and got a massive crack in the screen so i bought a new toouch screen online and followed one of the million youtube guides on how to replace it myself.
I Got it all working again but 1 problem -the LCD screen broke when I was attempting to "gently" pry it off the touchscreen so only the top 2/3 of the screen worked. Fml.
I ordered a new screen and digitizer together so i could change it all in one piece. Unplugged everything and plugged everything back in no trouble, easy as. I turned it on and the backlight lit up but I now have no display.
I know the #1 plug controls the LCD and i had a little trouble getting that plugged in with the new screen (took about 5mins), could i have screwed somthing up there?
I tried plugging in my old screen but the same thing happened again.
Это хороший вопрос?
Оценка 1
2 Комментариев
Fixed it myself. nevermind.
из
Nice job fixing it yourself! You are more than welcome to post an answer to your own question explaining what you did and then accept that answer so in the future people can fix this problem themselves.
из
Добавить комментарий
2 Ответов
Выбранное решение
Yepp that's exactly what was happening. Just connect it all up and close up the phone then reset the phone by holding the home button and the lock button for about 10seconds. Then turn it back on and it should work normally.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
You are an iPhone GOD!!!! Thank you so much. I had the exact same problem and this worked.
из
I've had the exact same thing happen but cannot fix it. Could you please let me know what you did to get it working?
из
Наиболее полезный ответ
well, most of the time, restart of the phone helps. you already fixed it yourself, next time, try to hold both power and home button until the screen switch off...
Оценка 1
Добавьте свой ответ
Candice будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 6,847
