Guides and repair information for cars and SUVs manufactured by Kia Motors
289вопросов Показать все
2001 Kia Sportage 4x4: Fuel Pump Fuse location
we have the 2001 Kia sportage 4x4. Replaced the fuel pump, but its seems to not be getting power to it. Where is the fuse location for that? My Husband looked by the door as another site said it was and its not there. is there any other possibilities of the car not running?
Это хороший вопрос?
Оценка 2
1 Комментарий
please give me some help. I have two vehicles not running. Husband is laid off work. We need to have a vehicle. thank you Kindly and God Bless
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Hi there, I am no expert at all. Just browsing the questions. Came across this, thought I'd help by doing some research for yah.
In case you don't have the owners manual anymore, I found one online, for that model of vehicle
http://www.kia.ca/content/ownership/owne...
Scroll all the way down to Page 200 of 303. There you will see the fuse box information.
My guess, there are 2 fuse boxes. 1) Located near the drivers side. "The kick panel"
and 2) under the hood.
Also, the fuel pump fuse is operated by the "Main" fuse located under the hood.
Hope this helps you. Good luck!
Был ли этот ответ полезен?
Оценка 2
Melody D Ham should be #17 in the fuse box under the hood. Also check the fuel pump relay (common failure on that model)
Оценка 2
Where location fuse fuel pump
Оценка 0
Добавьте свой ответ
Melody D Ham будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 45
За всё время: 6,098
