The Canon EOS 300D is a 6.3-megapixel entry-level digital single-lens reflex camera.
Why doesn't camera recognise a memory card is inserted
Camera is not writing files to the cf memory card and is saying a card is not inserted.
Это хороший вопрос?
Счет 0
Добавить комментарий
4 Ответов
Выбранное решение
maybe contacts are greasy. try to degrease it, any white spirit/alcohol will do. also, you might need to format/reformat the memory card using camera...
Был ли этот ответ полезен?
Счет 0
I've also discovered that this happens because of a bent pin in the camera where the CompactFlash card plugs into the camera. Mine has been the two pins closest to the eject button.
Счет 0
This can also be caused by a defective/broken CF door switch
Счет 0
Could it be for any other situations, as I have done all checks and keep the problem.
Счет 0
Добавьте свой ответ
Rob буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 2,748
