Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Вопрос закрыт
iPhone constantly searching for carrier (no service)
I have this iPhone with a badly broken screen. The lcd still works. The phone is not bend so the motherboard looks ok. Only problem is the phone keeps searching for carrier. what could be the problem?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
First, check the time and date is correct, as this can cause this issue.
Second, check that the IMEI and Modem Firmware is visible in settings. If it is not, you have what's called a baseband issue, and the device needs board level repair. There's a link on my profile for a website of trusted techs if you wish to find someone close to you.
If both of those things are OK it may still be a board level issue (iphone 6 are very common for cellular IC fractures) but it definitely needs to be investigated further by someone experienced
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 224
