4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
Вопросов 20 Показать все
PSP 2000 battery external charging
Can you help me my PSP 2000 can't detect any type of battery
I have the original battery but I think it died already, because it's old, when i plug the original battery it just blink orange light then green light, alternate then the orange light will be gone.
My psp only turns on when plugged in via charger, I tried using other psp batteries (brand new class a) so I plugged in the battery, it has the orange light a sign of charging but still it won't recognize by psp, the battery information says (battery external) and the other information are blank
I can use my psp/play games when plugged-in via charger no other problems except the detecting of the battery.
PSP 2000 japanese model
5.50 Prome-4
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Hi Nikko,
I've got the same issue. If you confirm that the battery you are referring to works on other PSPs, you may follow the link below. Hopefully we'll find a solution ;)
PSP working with power supply but functioning batteries not detected
Был ли этот ответ полезен?
Оценка 0
Nikko Mallari check the “Charging Fuse” If it does not show continuity and may need to be replaced, your battery won’t be found. Also check for bad traces on your circuit board as well as burned, loose or missing components around the power IC. To check it out use this SM with all the schematics you will need Psp-2000-Service-Manual.pdf
Оценка 0
Добавьте свой ответ
Nikko Mallari будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 8
За последние 30 дней: 13
За всё время: 720
