Can't connect to the internet
I am trying to use the internet browser on my Nokia Lumia 521 but the phone doesn't load any webpages.
Это хороший вопрос?
Это хороший вопрос?
You should first check to see if the Wi-Fi is on. Select Wi-Fi in the settings list and if it is off, drag the switch to the right and it should turn orange. If the Wi-Fi is already on, you should try moving closer to the source in order to obtain a better signal, and if that connection is still not working, you may be connected to the wrong network. Select Wi-Fi under the settings menu, a list of networks should appear, and select the network that you are trying to connect to. I recommend you also look through the troubleshooting guide.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 602
