Released September 2014, the LG G3 Vigor is smaller and cheaper than the LG G3.
What do I do if my device freezes?
My LG G3 Vigor froze on me while I was using it. It has been frozen now for the past ten minutes, what should I do to fix this?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Press and hold the "Power" button and see if the device would turn off. Wait a few seconds and then reset the device by turning the power back on.
Был ли этот ответ полезен?
Счет 1
Remove the case from your phone and remove the battery. Wait a few seconds,put the battery back in and after you do that, turn your phone on.
Счет 0
1 Комментарий:
Well, I had the same situation and always, I have to do the battery removal and soft re-start. This does not explain why just a simple re-start (On/Off cycle) using power switch does not work. During this freeze, only option is to remove the battery and re-insert and then do a soft restart. Any clues.?
из
Добавьте свой ответ
Jared Stickl буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 703
