An Android smartphone by Samsung for the Asian market, known by many model numbers, released December 2014. Includes models SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W.
118вопросов Показать все
Samsung A5 2016 screen replacement (A510F)
Hello,
Does anyone know how you change the display of the new A5 2016? I have opened the phone on the display side but the flex cable goes to the back side of the phone (unlike the old A5). Do you have to open the backside (a risk of breaking glass) or can you lift up everything inside to disconnect the cable (no screws visible on display side)?
Thx
Это хороший вопрос?
Оценка 0
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Hello
There is a tutorial video : https://www.youtube.com/watch?v=-N9mg53O...
Был ли этот ответ полезен?
Оценка 2
How can repair my samsung a5mobile ? Because my phone was damaged by rain fall touch is not working
Оценка 1
Although I am not familiar with this particular samsung phone, I have done screen repairs on the s6, s6 edge, and note 5. All of them require the back glass to be taken off and then screws are underneath. A lot of heat is required to loosen the adhesive holding the back glass so make sure the phone is turned off.
Оценка 0
Its same as a3 2016 you have to open the back screen to unscrew the motherboard. No other way but its not difficult u need a hair deyer and a raser blade and slowly slowly peal it of like orange. :-) ive done it myself.
Оценка 0
1 Комментарий:
Where did you buy youpr screen?
из
You need to open up the back first. So you take off the back cover with a heat gun, remove all the screws (also don't forget to take out the SIM tray) and then you can take off the midframe. After this you can disconnect the LCD flex cable!
Оценка 0
How can I repair my samsung a5 2016model? Because my phone was damaged by rainfall
Оценка 0
2 Комментариев:
What does it cost to replace Samsung A5 2017 screen
из
Hi so I recently dropped my phone (a couple of times lol) and so as a result of that, I managed to break/ smash my LCD screen and also the back cover; I was wondering how much it would cost to get both fixed?
из
Добавьте свой ответ
Robin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 32,632
