The Samsung Galaxy Alpha smartphone was released in September of 2014 and is also known as the Samsung Galaxy Alfa. It runs on the Android operating system and is carried by most major cellular providers.
How do I fix the black screen?
I dropped it on a hard surface with the screen protector on , it powered up ,the volume buttons work and notification sounds are on but the screen remained black. How can I fix it?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sounds like you broke the LCD. If you are sure the Device still turns on then the LCD is likely to be damaged.
You would need to replace the screen there is a guide on how you can replace that phone Samsung Galaxy Alpha Display Assembly Replacement
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
madastfleur буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 3,354
