The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
300вопросов Показать все
HELP!Near the SD card reader pole SMD specifications
Near the SD card reader have a smd inductance ,who can help me make sure it's specification ,
Its position as illustrated
... Thanks
更新 (2016年03月04日)
It was gone this is mca air A1466
as illustrated
Это хороший вопрос?
Оценка 1
2 Комментариев
Are you using hot air or just soldering iron for those jumpers?
And why did you need them to begin with?
из
because the original disappeared
из
Добавить комментарий
1 ответ
Выбранное решение
@chenyuchih it is a bit difficult to identify exactly which component you are pointing to. A image straight down somewhat zoomed out would work better. Right now it looks like the component you are pointing to is L4400 which is a 47NH-1.3OHM inductor in a 0402 package
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
thanks for your answer ....thank you very mach...when I back home I will take a picture then could you answer me again please
из
@chenyuchih thank you for the additional images. It verifies that the component is L4400.
из
Thank you very mach ,
из
Добавьте свой ответ
chenyuchih будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 136
