Шестое поколение iPhone компании Apple, представленное 12 сентября 2012 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в Черном или Белом цвете.
2522вопросов Показать все
Repaired water damaged iPhone is having some problems
i dont know if anyone can help me on here.
iphone 5s water damaged.. i cleaned it properly. it worked but::
1 sucks alot of power (battery draining fast)
2 every 5 seconds of use it gives a warning. " temperature too hot cool down before use"
.. i can touch the motherboard and feel that its on normal temperature not hott..
solutions as per my experience:
battery draining fixed by replacing u2 ic.
any solutions for temperature too hot warning, any ideas where to look on motherboard for this..
thanx in advance..
Это хороший вопрос?
Оценка 0
1 Комментарий
Hi remove all the metal brackets, switch the phone on and try to find where the heat is coming from. There should be component that is overheating. If you find it you have to replace it and then phone should work fine.
из
Добавить комментарий
1 ответ
Выбранное решение
First don't repair liquid damaged phones if you can. They're a nightmare and keep coming back for various issues.
Second, try a new battery. A known good battery of great quality or at least different source from the one you have in there if you already replaced it.
If that doesn't fix it, and you still experience fast battery depletion, heat, and still see this message, then you have a short somewhere. This short may be producing heat and activating this temp warning message.
If you see the message without heat, then one of the heat sensing resistors on the board was damaged from the liquid spill.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
brisbane wholesalers будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 76
