How do I find reactivation code for radio
My car radio is deactivated and u don't know my code to reactivate it
Это хороший вопрос?
Это хороший вопрос?
@amelia1 there are a couple of things you can try:
1. Look in glove box for small sticker with numbers, should be 5 digits with numbers no greater then 6.
2. Pull out the ashtray and see if the sticker is on the back of there.(older models that have them)
3. Pull radio from dash and write down radio serial number and call local dealer with that number and they will be able to get the code for you. They will ask verifying questions.
One more thing you can do is that Honda has a radio reset website, this is an automated service that can provide your Honda stereo code. Just write down the serial number of your radio and the VIN number of your vehicle then contact Honda. The VIN number is located on the driver side of your Accord vehicle just behind the windshield.
You could also give this a try:
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn car to ON II(radio powers up)
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Turn radio off
Hold 1 & 6 buttons on radio
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)While still holding 1 & 6, turn radio on
Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. ##)Write down the 8digit number that should display
Call your Honda dealer and give them those numbers.
Был ли этот ответ полезен?
I don't know how battery was dislocated radio off not great with technology or tools need code 1998 honda accord CV ord
Not good with none of the technology
За последние 24часов: 3
За последние 7 дней: 32
За последние 30 дней: 129
За всё время: 41,630
10 Комментариев
You can get a radio activation code here: https://radiocodevault.com/honda
из James
That site is a scam. You dont have to pay $@$*. https://radio-navicode.honda.com. got a free code.
из Jonathan Burton
Ended up getting my radio code from https://radiocodevault.com/honda/ for my honda odyssey, works on all models though. Great service, and gave me a working radio code. Don't know what the commenter above is complaining about, cheapskate I guess. I wanted a solution that actually WORKED.
из poglitsch
www.radiocodevault.com unlocked my honda. Gracias everyone.
из juan jojc
2000 Honda Accord stick 4C radio code
из Rachel ostrand
Показать 5 больше комментариев
