The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211вопросов Показать все
How do I get pass the logo screen?
I need help. My galaxy note 2 will not let me do nothing but turn it on. If i try to wipe it or hard reset it it says it failed
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hello there!
Try to upadate firmware via samsung kies. if the samsung kies not be able to fix your fault you may have to flash the phone by flash tool.
Был ли этот ответ полезен?
Оценка 2
you can turn your phone into download mode* and then you can install stock rom**, and then it should work for you.
if it's not I don't have any other solution.
Good luck!
Raz
Email: Rluvaton@gmail.com
*to enter your phone into download rom you have to install Odin on your computer first, then (when your phone is off) press the volume up and the power button untile the logo showed up, then it will enter you into download mode
**To install rom stock you need to google - "Samsung Galaxy Note 2 Rom Stock" (you can add your country name if you wish)
Оценка 0
Добавьте свой ответ
another savage будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 100
