I had the same problem, but I solved it, my sister put a full size sim card without the tray, So the solution to this problem is : You use sewing needle, that you heat up with a lighter or candle, and you insert this needle in the stuck simcard as deep as you can, and wait 2 sec before trying to pull of the needle. You may have to try is a couple of times, but try to heat the needle a lot and handle with tweezer or something. That will definetely work, because that works perfectly for me, don't try to open the phone it's just a pain in the ass to reassemble it after.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
43
22 Комментариев
Hi. My sim card got stuck and I used a small safety pin without bending or heating it and slided it down the side and when it reached the bottom I bend it backwards and the sim card flew out
из Sharon Fitzpatrick
Hi Sharon. Well, yes, that IS one way to remove that pesky simcard, however, I guess my patience just didn't quite match yours, but, my method is a bit quicker. I simply used one round from my Glock nine-millimeter. It was pretty-much instantly removed....although that did not seem to fix the problem. BUT, it does give me the good reason to go out and buy a brand-new-shiny tablet, and, I suppose a new dining room table, china cabinet and, of coarse I'll be needing to replace our jumbo-screen T.V. as well. Oh , yeah, an' put up a picture or something over that hole before the wife comes home. Relatively common here, y'know replacing stuff....umm, we live in California. But, hey, thanks for sharing YOUR method Sharon. 'Sharon-shar-a-like' I always say....I, ah, I always say that. Anyway, I think I will certainly give that a try next time...probably.
из Allen Cook
Oh, it's just me again. Before leaving to get those replacement items Ì need, I thought some of you might be interested in knowing that I just found that discharged slug from my tech-procedure that I performed about an hour or so ago. Seems it was in the master bedroom, halfway-embedded into our Italian-marble-enclosed-bathtub-surround about three-feet past the shattered hand-etched and multi-color-stained-glass-shower-door. Oh, well...I'll also need to have the contractor guys come out to renew what they remodeled last summer. No problem, no REAL harm done here. Not NEAR as bad as the last time. Well, I'd better get goin'. Just wondering, though, WHY do we even HAVE sim cards in our stuff anyway?
из Allen Cook
The tech said “remove the sim card” so I did, using the only available thing, my earring, to poke in the hole. The sim card and the tray flew out on separate trajectories. I found the sim card but not the tray, so put the card in by itself. Bad move. Phone wouldn’t work and I couldn’t get the card out again. I tried all the remedies I could find on google, without success. It took hours. Hours more on the phone going up and down the Apple ladder until my husband found someone who knew someone who knew what would do the job. TAKE TWO SLIM PAPER CLIPS. SLIDE THEM DOWN ON EITHER SIDE OF THE CARD, THEN USE THEM TO WALK THE CARD OUT OF THE SLOT. It worked! The card suddenly flew out towards parts unknown, and I am in the process of looking for it.
из Anne Jehle
P.S. Unfold the paper clips first so you have a long poker.
из Anne Jehle
Показать 17 больше комментариев
