Второе поколение iPhone. Модель A1241; 8 или 16 ГБ памяти; с черной или белой задней пластиковой крышкой. Ремонт проще, чем первого iPhone. Требует отвертки и инструментов для вскрытия.
1158вопросов Показать все
Вопрос закрыт
iPhone doesnt turn on and restore after glass change
this afternoon I changed the glass and the touch screen of my iphone 3g, following your tutorial, and changing it, it was stopped at black screen with the apple as if they were carrying, but he was not coming to screen boot, so I changed the hosts file and was trying to restore it, put it in recovery, dfu, tried with the 4.0 fw 4.0.2 and nothing, in itunes it is "preparing iphone for restore" but always errors 1604 and 1603 was the result. It may be some incompatibility problem of the touch screen? if not find a solution quickly, I think I'll end up upgrading to 4.1
thanks and I await answers!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hey up, open it up again and see if you haven't damaged the mobo as by looks of it thats the case. Also try to do a 'master reset' by seperating the mobo from the battery... simply take the motherboard out for 1-2 minutes. When putting it back together make sure you gonna connect everything correctly.
I have had similar problem 3 or 4 times and doing 'master reset' helped everytime apart from a single time when i managed to break components off :(
Был ли этот ответ полезен?
Оценка 0
5 Комментариев:
I changed my battery and now iTunes doesn't recognize my iphone!
из
check batteries volatage as it might be 'dead'
из
its the same the original one, and my iphone turns on, but stays on usb cable pointing to itunes logo screen, and when i plug it with the computer it doesnt appear on itunes
из
wait did you purchase it with faulty screen? or you dropped it etc? was it working with the broken screen?
из
no, no i'm sure i did all the process correctly, and now i'm starting to believe it's bricked, do i have anything to do to save my iphone? i'm almost sure it's a software problem, thanks!
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 1,484
