Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342вопросов Показать все
What kind of graphics card can I upgrade to? Raedon r9 290?
I was looking at upgrading my graphics card to something a little better for gaming. I was looking at the Raedon R9 series preferably the 290 or 390. The problem is i have no idea how this works so I don't even know if these will physically fit in my computer. So can I upgrade to either of these (or another graphics card on par with these)?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Sadly, you cannot upgrade the graphics card in an iMac. There is not an actual graphics "card" so to say inside of an iMac. Instead, the GPU itself is soldered to the logic board. If you need more performance, you may want to consider selling your current iMac and putting that money towards purchasing a newer model.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
the iFixit website has a guide to replacing the graphics card. Is this just for replacing with the same exact thing or is it possible you're mistaken? (not trying to be rude, I honestly no next to nothing about this, I'm just trying to be sure before I give up)
из
I am so sorry, I was thinking about the newer iMacs. Yes, you can replace the graphics card in your machine but you can only replace it with one that is identical to the one that is already installed. You cannot upgrade it because newer cards have higher power requirements and run hotter.
из
Добавьте свой ответ
Carter Hobbs будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 184
