Вопрос закрыт
Everything is large after screen replacement.
Hello, I broke the screen for my HP Envy laptop and now I've properly replaced it with another I purchased, which can be seen below:
https://www.laptopscreen.co.uk/HP-Compaq...
The issue is everything on the screen is larger than what I previously had with the old screen, I've tried many methods to fix this but none have worked so far. I believe the issue might be that I've misread and made the mistake of buying the 1366x768 screen instead of a 1920x1080 resolution screen ...
Any input would be greatly appreciated before I go through the pain of taking my laptop apart again and having to get yet another replacement, thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hi,
replacement screen have got lower resolution that original one so the only solution is changing screen font size in Window's Control Panel ..or replacing the screen with correct one :)
Regards,
Kris
Был ли этот ответ полезен?
Оценка 0
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 82
