The Black and Decker Air Station is a 160 psi air compressor that is designed to inflate a range of household items.
2вопросов Показать все
Air station quit working
I a ired up one tire then hooked my air station to another tire but the air station would not come on.I checked all I could check but it still would not come on.What can I do?Did the ac dc switch suddenly go bad?
Это хороший вопрос?
Оценка 1
1 Комментарий:
My air station will not blow up my tires. It blows air when not attached to the tire. HELP
из
Добавить комментарий
1 ответ
I just got me one of these at goodwill for $40 and I wish I had my money back! Your Air Station stopped working because the fuse blew just like mine did only the second time I used it. And guess what? I had to take it apart to get to the small fuse inside and this is a pain in the ass because you have to cut out the old fuse and solder in a new one.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Hi,
There's always a reason why a fuse blows, so don't be ssurprised if it happens again very soon.
Fuses blow because excess current is flowing through them due to a problem in the circuit that they're there to protect e.g. short circuit turns in the motor winding or a component that has changed value for whatever reason.
What is the model number of the device?
из
Добавьте свой ответ
george m denison будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 20
За последние 30 дней: 48
За всё время: 1,144
