How to Disassemble JBL Pulse 2
How to disassemble JBL Pulse 2 or is there any other way non damaging to fix the dent in my speaker??
Это хороший вопрос?
Это хороший вопрос?
take the rubers out from the sides and you will find out 4 screws under that cap you will find another 4 take the rubers out and in front of the bottons unscrew the cap and unplug the collor sensor and the bottons pull the cover out . YOU ARE INSIDE THE JBL PULSE 2. I also have upload a video in youtube with some helpfull images. https://youtu.be/wmQrxOqkEx8
Был ли этот ответ полезен?
how to remove the rubber on the sides can you please show some pictures or videos tnx
Awful video. Just a guy showing his disassembled pulse 2 from all angles to some $@$*!& music.
Assembly of the speaker includes a lot of 'glue' so- so taking one apart is a pretty difficult process (if you expect to put it back together).
Go slowly, use a small screwdriver, knife, scraper - and a heat gun That is your best chance of having something you can put back together.
My JBL Pulse 2 has a broken micro usb charger port! I can see the problem! One of the little prongs inside has broken off. Is there any way to fix it without having to replace it?
i saw some technic in youtube just check it out tnx
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 13,322
