Why is my battery life draining so fast?
I’m using my Kindle to read for only a few hours a day and the battery life is always low. Why is this happening? Is something wrong with my battery or Kindle?
Это хороший вопрос?
Это хороший вопрос?
That is a common problem that happens. Good question!
You may not be using the optimum settings on your device. It is recommended that you set the Brightness to 10 and turn on Airplane Mode when the Wi-Fi is not being used. While this will extend the battery life, it is also dependent on how long you use the device for each day.
If you are still experiencing battery life problems, you may indeed have a faulty battery. In this case, you may need to replace your battery.
Был ли этот ответ полезен?
Please tell me where I can get a new battery.
Where can I buy the new battery?
It happened to me also after firmware update in March 2016. It is a bug in the version 5.7.2.1 - something with indexing books. Fixed with manual download a install version 5.7.3.
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 74,351
1 Комментарий
My Kindle is only 7months old but the battery is running low after a single day reading. Really baffled and disappointed. Is this normal ?
из Manonabike101
