The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
41вопросов Показать все
Вопрос закрыт
Why does my game gear not move right?
Why does my character always move to the right even when i am not touching the control pad?
Это хороший вопрос?
Оценка 0
1 Комментарий
The button seems to be worn out, but as far as how to fix it, I wish I knew.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I'm not familiar with the insides of the game gear, but like R Trent says it does sound like the d-pad may be worn out. Open it up and look under the hard plastic d-pad. Controllers use a contact that conducts a signal via a carbon-impregnanted pad attached to a rubber cup that acts as a spring for the button. The rubber may be broken so the pad can't spring back causing this constant right press. Fortunately, many controllers use the same d-pad setup. You can probably get a cheap controller and replace the rubber cup setup in your Game Gear. Use this guide to help you open it up.
Game Gear Guide
NOTE: from what it looks like it also has a 'Gamebit' security bit, but if its 3.8mm you can probably get away with using a 3.0U Spanner to open it up.
Был ли этот ответ полезен?
Оценка 1
I had the same problem, I met an electrician who told me just to use a designer eraser (the soft, white one) and erase the contacts between the base and the controller... if was due to dirt woyuld have worked.
So I did and it worked just fine
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 2,694
