The Pebble E-Paper Watch is a smartwatch developed by Pebble Technology and released in 2013. The project is under continued development and funded by Kickstarter contributors.
13вопросов Показать все
What screwdriver do I use? (OG Pebble w/4 screws on back)
I heard it was a Torx. Upon further research I discovered there are different types of Torx. The screws securing the back of the Pebble Classic down do in fact have the pin in the middle of each screw from what I can tell. Can someone point me in the direction of the cheapest possible online source to purchase the correct screwdriver to open up my Pebble?
I RMA-ed it and the replacement is on its way - but they're letting me keep my current one so I'm going to try to fix the screen tearing using the method I saw on YouTube with the shim adding pressure to help ensure a solid connection for the display cable. And if something goes wrong beyond fixing, then I'll just go to a facility to recycle it like Pebble Support told me to. It's the defective one anyway.
Model 301BL, the later version that actually can be opened without completely wrecking it.
I just have to tell myself that it won't be long before I have an Apple Watch Sport. I'm willing to sacrifice battery life for something that will actually work.
Это хороший вопрос?
Оценка 3
Добавить комментарий
3 Ответов
Наиболее полезный ответ
I found that the T5 Torx was the one that fit the screws.
Был ли этот ответ полезен?
Оценка 2
Sounds like the model you have uses Torx-Security screws. We have a few different sizes, but this is one of our smaller ones:
TR6 Torx Security Screwdriver
TR6 Torx Security Screwdriver Изображение
Продукт
$5.99
Оценка 0
Torx 5 is what I used. Fit perfectly
Оценка 0
Добавьте свой ответ
roycerivard123 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 3,831
